Old 12-07-2019, 04:21 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Line to Line coating
Anyone tried this on a stock or super or stocker, Did it help or hurt performance, How tight did you run the pistons?
Old 12-07-2019, 08:02 PM   #2
SSDiv6
Default Re: Line to Line coating
Have tried it twice, it works and it helped bring the wall clearances back at 0.005" for 2618 alloy pistons. Also, follow the break in instructions and you will be fine.
It is being used by many professional engine builders successfully.
Old 12-08-2019, 09:43 AM   #3
Alan Nyhus
Liked 800 Times in 237 Posts
Hey, Jim...I've seen Steve Koppien use it a few times, as well as several other people you would know. Some engine builders use it on fresh builds. It works. -Al
"That'll never work....."
