Old 11-07-2019, 11:47 AM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default winter car
what do you use in the block to keep from freezing
i allways use rv pink
but i was told not to use
the car is in a grage
Vic Guilmino 1129 STK
Old 11-07-2019, 11:54 AM   #2
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: winter car
Just did this last night... I drain all the water out, refill with green antifreeze, circulate it for 10 to 15 minutes, then drain the antifreeze out. I let it sit with the drains open all winter. Never had an issue. My car is in a garage, but my garage gets pretty cold in the winter.
Old 11-07-2019, 04:38 PM   #3
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Why not leave the antifreeze in all winter ?
Old 11-07-2019, 05:06 PM   #4
Jeff Jewell
I don't trust the 50+ year old cylinder heads...
Old 11-08-2019, 08:29 AM   #5
Liked 11,033 Times in 2,268 Posts
Dont forget to fog it down
Old 11-09-2019, 08:54 PM   #6
hilton
Liked 19 Times in 9 Posts
My engine builder told me not to leave the anti freeze in all winter, fill flush then drain, race gaskets don't like anti freeze
hilton is offline   Reply With Quote
Old 11-11-2019, 01:42 PM   #7
Greg West
Liked 52 Times in 22 Posts
Do you back off the rockers when the car is stored for the winter?
Most race gaskets are made with the same materials as production car gaskets (the exception is copper gaskets). Why would anti-freeze damage gaskets?
Greg West is offline   Reply With Quote
Old 11-11-2019, 09:24 PM   #8
cmracing
Liked 62 Times in 29 Posts
I have never backed-off the rockers. I have always drained the radiator and refilled with straight anti freeze, holds 1 1/2 gallons, then run the electric water pump for 5 minutes, then away it goes. Sometimes I would go visit it once a month to turn it over by hand 180*. Don't know if it needs to be done, but at least I got to visit her. Always stays in the trailer at the track, but soon she will be able to stay with me!
cmracing is offline   Reply With Quote
Old 11-11-2019, 10:03 PM   #9
Tim H
Tim H's Avatar
Always backed off rockers,filled with antifreeze.
