Old 11-01-2019, 11:09 AM   #1
4speedracer
Liked 10 Times in 6 Posts
Default radiator foxbody
Anyone know of a source for a single core all aluminum tank radiator for a fox mustang, all I can find in aluminum is multiple row. Not sure about plastic tanked replacement radiator any issues with them? Thanks
4speedracer is offline   Reply With Quote
Old 11-01-2019, 01:12 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: radiator foxbody
I have been running an AutoZone replacement with plastic tanks, since the rule change allowing aftermarket. It is a single core. Why spend a bunch of money on a all aluminum if the replacement works?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 11-01-2019, 05:30 PM   #3
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Have you tried NPD?
Mitch Beri- The Motor City
Old 11-02-2019, 02:28 AM   #4
Rory McNeil
I have also been using a cheap replacement aluminum with plastic tanks radiator , made by Spectre Premium, from a local parts store in my Ford FOX car, for the past 2 years. No issues, bolted right into the factory mounts, lighter, and runs cooler than the old, partially clogged old brass rad. And the new rad was cheaper than what a wrecking yard wanted for a used stock unit.
NHRA 6390 STK
M/S 85 Mustang
Old 11-05-2019, 03:43 PM   #5
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
I bought a spector from Rock auto for like $75 works great!
https://www.rockauto.com/en/catalog/...,radiator,2172
fred goodwin is offline   Reply With Quote
