Old 10-19-2019, 11:40 PM   #1
Tex013
Liked 48 Times in 27 Posts
Default Drag radial life/ max passes ?
Hi ,
I know a lot here run either Hoosier or Goodyear radial slicks
What lap life are you achieving ? Car is 3780lbs Plymouth Satellite 680hp big block , 4.1 gear transbrake , 10" rim
I currently run MT pro bracket radial 29.5x10.5 but there is none newer than 2016 available here in Oz and no idea if newer coming .
I would like to see 100-125 passes minimum . This is bracket racing car runs high 10.20s , 1.42-1.44 sixty .
If there was a true 29" radial i would be happy , quickest pass ever was on a 28"PBR , and think the 30" may be just a tad too tall . I have run Hoosier 275s before but only got 70-85 passes . Never run Goodyear .
TIA
Tex
Tex013 is offline   Reply With Quote
