Old 10-10-2019, 10:11 PM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Stock eliminator engine bearings
What brand or type of bearings are you guys running in Stock Eliminator?
Are they coated?
littlemanjoe is offline   Reply With Quote
Old 10-11-2019, 05:17 PM   #2
SSDiv6
Default Re: Stock eliminator engine bearings
Are they coated?
ACL
Clevite
King
Coated when apllicable.
Old 10-11-2019, 05:45 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
What do Coated Bearings do over non Coated Bearings?
Old 10-11-2019, 09:09 PM   #4
SSDiv6
They only help in cold starts only.
If the parts are machined correctly and all clearances are right, there is no need to coat the bearings since they already run on an oil hydrodynamic film.
My preference is to run coated cam bearings and non-coated mains and rods.
Old 10-12-2019, 07:18 PM   #5
Nmbr1GMfan
IMO coated bearings really shine when the oil pressure is funky, like when you run low oil levels for performance reasons and maybe the oil pressure will hop around (low) during the run a coated bearing will outperform hands down. In a nut shell, a bearing coating is there because of it's wear resistance.
Todd Greene
