Old 10-06-2019, 07:13 PM   #1
Makinchips
Default BBC cyl heads
Has anyone dynoed a closed chamber head versus an open chamber head?
I have an older friend that keeps telling me it's a 50hp gain.
Since i run a 402 in my bracket bomb and wouldn't mind throwing some more power in it I'm hoping someone on here may have some results
Makinchips is offline   Reply With Quote
Old 10-06-2019, 10:11 PM   #2
Barry Polley
Guest
Posts: n/a
Default Re: BBC cyl heads
Just for ref... find your heads and compare.
http://users.erols.com/srweiss/table...hevy_Big_Block
Old 10-07-2019, 12:49 AM   #3
HP HUNTER
Liked 372 Times in 129 Posts
Super Stock 396s make 750 HP with 215 heads, so are you utilizing 750 HP @ 131 MPH? Get those closed chamber heads to someone who knows how to work them. :
Example:
396/325 SS/GA 143 MPH @ 3350 = 754 observed HP
Old 10-07-2019, 10:31 AM   #4
Makinchips
How much rpm would it take to achieve those numbers?
Who does that type of work?
My cyl heads are on the wiess list 291 BBC Mchips.
Old 10-07-2019, 11:07 AM   #5
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Jimmy Bridges in Nashville (615) 228-3516, simply "The Best".
MAURICE BLENDHEIM is offline   Reply With Quote
Old 10-07-2019, 11:32 AM   #6
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
SS big block commonly run over .800 lift and utilize every trick in and out of the book to achieve the performance numbers mentioned. I was a bracket racer for more than 30 years and I can tell you that in most cases open chamber is easier to make hp with. The 049 and 781 open chamber oval port heads can run really strong with an upgrade to 2.19" and 1.88" valves and short side radius work. The late great John Lingenfelter proved this many times.
Old 10-07-2019, 10:05 PM   #7
HP HUNTER
I was talking oval ports, now 291s are a different world. Bridges would be good, but there are others as well. Some like to forget..............
Name:	Vortecpro Oval port.jpg
Old 10-07-2019, 11:09 PM   #8
Makinchips
Back to the original questions not straying.
Mark i like the red car in the pic it has nothing to do with the questions posted.
Old 10-08-2019, 07:40 AM   #9
HP HUNTER
Feel free to call me. You will have to turn RPM to utilize the 291 head. Whats your drive line like? It might be best to build a 4.350 X 3.766 short block.
