Old 09-23-2019, 11:19 PM   #1
HawkBrosMav
Liked 302 Times in 73 Posts
Default C4 Transmission issue
We’ve got a pretty good rpm flash during the 2-3 shift. I’ll have to look at the logs, but shift around 5900 on the tach and you can see the tach flash up to about 6400. The 1-2 if there is a flash is much less noticeable on the tach itself.
This has been something we’ve noticed much more since we took the stock 1st gear out and put in a 2.92 ratio. I personally don’t know why that would give us a flash unless when reassembling we got something adjusted incorrectly. Just swapped to a brand new ATI converter and a different cam recently and the car is as fast as it has ever been but the flash seems to be worse.. any suggestions on making it go away and/or if we are losing ET because of it?
