Old 09-21-2019, 01:52 PM   #1
Jeff Stout
Liked 708 Times in 285 Posts
Default Voltage in radiator water
Getting finished with list of problems. Previous I had high water pressure after car sitting for days. Cap was 16lb. Changed to a 13 lb lever type. I do have stock overflow and open hose to it. Something I was told to check was electrolysis in water. I tested and have .3 of 1 volt in water. I did not put a anode rod in.
My question is .3 volts a problem?
Do I need a anode rod?
Thanks
