Old 09-17-2019, 03:46 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Legality questions in stock
Few questions since another thread has blown up over engine combo avgs lol. Couple questions for STOCK
1. Does aftermarket crankshaft HAVE to be on the accepted list if it is legal by weight and design?
2. Is crank trigger ignition ok if it did not come with a crank sensor?
3. Can you run coil near plug system ( 8 coils like and GM LS engine) if it did not come that way from the factory?
Just curious questions....asking for a friend
jamie2370 is offline   Reply With Quote
Old 09-17-2019, 04:18 PM   #2
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
Default Re: Legality questions in stock
No no no
Old 09-17-2019, 04:31 PM   #3
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
The crankshaft can be added to the list if it checks out. There is a form and you or the manufacturer have to send it in to NHRA for approval.
Pedigo Perf is offline   Reply With Quote
Old 09-17-2019, 11:59 PM   #4
cmracing
Liked 62 Times in 29 Posts
#2 is a maybe. If you are running an LT-1 with the Optijunk setup you are allowed to run a crank trigger.
cmracing is offline   Reply With Quote
Old 09-18-2019, 02:48 PM   #5
baccaruda
baccaruda's Avatar
Liked 2 Times in 2 Posts
Boy things have changed from the good ole 60 and 70's i really miss those days...
baccaruda is offline   Reply With Quote
Old 09-18-2019, 03:20 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Can you use a Torque Head system on a LT1?
Old 09-19-2019, 04:11 PM   #7
cmracing
Yes and no........... Once again.
You must use the Optijunk as a "distributor", the coil wire must go into it and get distributed to the 8 cylinders. You can not use individual coil packs.
You can use parts of that Torque Head system, but you can only use a single external coil.
You can use any ECM you like, I prefer the new Holley stuff, and no traction control devices.
We have modified the Optijunk units to give us a cam sync signal for sequential fuel injection and use an external crank trigger in tandem.
Old 09-19-2019, 04:55 PM   #8
Dan Fahey
Dan Fahey's Avatar
Is this Corbitt:
Hello !
Old 09-19-2019, 10:54 PM   #9
cmracing
Is this Corbitt:
Hello !
Nope, Pistol Pete and a few others know me very well. I usually use my real name, but chose to stay "hidden" on this site.........
Old 09-20-2019, 04:24 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You might be able to run multiple coil system in Super Stock
