Old 08-29-2019, 09:37 PM   #1
cameron4link
Default 1985 z28
I have a question! I have a 1985 z28 IHRA crate motor car with a 350 and a glide that I bracket race .If I wanted to run NHRA stock eliminator what are my options ? Do I have to run a 305 ? And can I run a glide or do I need a 3 speed ? I am from Canada and will mostly run a couple of combo races so I think I could run it as a crate motor car at those races but am interested in making it an NHRA stocker. Not looking to brake records I just already own the car and want to have some fun thanks in advance !
cameron4link is offline   Reply With Quote
Old 08-30-2019, 05:53 AM   #2
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Lightbulb Re: 1985 z28
You will have to run the 305 and I would look to see what combo would be the best. In 85 to 87 they had a few different 305 combinations and one might be easier. To update the body from year to year is easy. ( hood and bumpers). The 3 speed trans is faster and a metric 200 would be the way to go. Good luck . What part of Canada are you from?
The more people I meet the more I like my dog
Kevin
Old 08-30-2019, 07:02 AM   #3
cameron4link
Default Re: 1985 z28
Just west of Ottawa in Ontario ! So I’m close to the Napierville race in Quebec !
Old 08-30-2019, 05:34 PM   #4
Pistol Pete
Pistol Pete's Avatar
Liked 769 Times in 206 Posts
You can run a 350 in it and i think the best 350 combo is a 90 Camaro.
Or a 305 definitely in any year.
"Pistol" Pete Dutko
Old 08-30-2019, 05:59 PM   #5
Lee Valentine
Liked 319 Times in 68 Posts
Make it an 87 350 tpi good combination.
Lee Valentine 1661 STK
Old 08-31-2019, 06:31 AM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 965 Times in 306 Posts
Lee 87 350 tpi is at 285hp
Old 08-31-2019, 07:51 AM   #7
PJ305
Liked 5 Times in 4 Posts
87 305 tune port @ 237 hp makes K/SA 8 hundreds gift on index!
PJ305 is offline   Reply With Quote
Old 08-31-2019, 02:02 PM   #8
jamie2370
Liked 239 Times in 90 Posts
90 was 1st year of flat top 350, 88 is least factored 350 but it is a dish piston motor. 85-90 z28 is same car outside with exception of cluster in 90 model. If you want a carb motor then 305 is your only option and that combo I think is best in a 84/85 coupe car, not a z28. I think 86 up all had ground effects.
jamie2370 is offline   Reply With Quote
