08-15-2019, 09:44 AM | #1 |
Liked 275 Times in 25 Posts
Stock and S/S hoods
A question concerning Stock and S/S hoods was recently asked and answered on NHRAracer.com dated 8/6/2019.
http://nhraracer.com/content/general...508&zoneid=132 Question: Can I remove the hood latch and use hood pins on my Stock / Super Stock entry? Answer: Per the 2019 NHRA Rulebook sections 11A and 12A pages 11 and 9 under Body:7 Hood it reads "Full stock hood including latches, hinges, springs, brackets, and braces as originally produced must be retained." With that said you may add hood pins, in addition to the original latch. This rule is for vehicles running in Stock, Super Stock, and Super Stock GT. Last edited by Travis Miller; 08-15-2019 at 09:49 AM. |
06-13-2021, 03:22 PM | #2 |
Liked 45 Times in 41 Posts
Re: Stock and S/S hoods
Travis,
Sorry to bother you here, but it was suggested (see link from the very quiet Nostalgia section) I contact you regarding an old Fairlane question. I tried messaging but that didnt work. Basically, was the 66-67 Fairlane ever NHRA legal with glass hood and SINGLE 4bbl, back in the 1960s? See link & picture of guide from (Mid?)-1968, lists only flat-hood-4v, flat-hood-8v, and glass-hood-8v. But it seems like a glass hood SS/C=7.70 or SS/D=7.70 car wouldve had to be a single 4bbl. Wondered if you knew or eg what the McCain or Brewer cars had then, 4v-glass or 8v-glass? https://classracer.com/classforum/sh...ad.php?t=79519 |
06-13-2021, 04:12 PM | #3 | |
Liked 4 Times in 2 Posts
06-13-2021, 05:18 PM | #4 |
06-13-2021, 05:33 PM | #5 |
Liked 9,557 Times in 1,987 Posts
I think John Cooper and the green. 67 convertible 427 / 410 both had flat hoods.
06-13-2021, 10:31 PM | #6 |
Liked 151 Times in 48 Posts
You can run the 2-4 or single 4 with the hood scoop ...I have ran both combos for years...
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
06-14-2021, 07:52 AM | #7 |
Liked 808 Times in 216 Posts
Does the Hood rule apply to the new cars from the factory??
Don Kennedy 7701 SS |
06-14-2021, 09:13 AM | #8 | |
4v flat hood 8v flat hood 4v glass hood 8v glass hood But it was strange back in the 1960s. The only class guide I have a page of is from 1970, but dates back to some time in 1968. It lists ONLY: 4v flat hood 8v flat hood 8v glass hood So I conclude the 4v glass hood was NOT legal circa 1968-70. And, the Fairlane seems to disappear from the wins/records in W/P=7.70 class in 68-70 which would jive with a change in the rules. Maybe because of the way they were factory built: 66 was all glass hood 8v (all 57 of em) 67 was all flat hood, 4v and 8v So when they started running too good in 1967-68, NHRA was looking for ways to cull the herd down to what was actually factory built combos. Just a guess. So long ago, I was a kid then. But in 67 and early 68, Fairlanes set records in the W/P=7.70 class. I figured, well, they just ran the flat hood 4v, which was W/P=8.00 or so. But then I saw McCain's car from 1967-68, with the glass hood, apparently running 1967=SS/C=7.70 and SS/D=7.70 in early 1968 ie Pomona. So I figured, ok it has to be a 4v under that hood because an 8v wouldve run in SS/B=7.00 class. The flat hood 4v is so much easier, the rules never changed, no factoring, etc. Trying to capture all the history of the 1960-71 era! Thanks Last edited by DeuceCoupe; 06-14-2021 at 09:49 AM. |
06-14-2021, 09:40 AM | #9 |
Liked 928 Times in 241 Posts
I believe you can run hood pins on any car, but the latch and hinges need to be all there.
The fiberglass hood is a 427 Fairlane only thing that is being discussed I believe
Duane Hoven 1342 SS/GT Last edited by 1347; 06-14-2021 at 09:43 AM. |
06-14-2021, 09:53 AM | #10 |
Liked 266 Times in 86 Posts
The 66/67 Fairlane 427 hood NHRA history is full of twists and turns.
This is based on my personal experience, at the US Nats in 1988 I showed up with a 1966 Fairlane 427 410hp single 4 barrel/automatic transmission with a class hood, Travis Miller told me my hood was incorrect and I needed to change it to a steel hood/hinges/hood latch setup. He also told me he had all the info on all the 1966 Fairlane 427 cars that had been built by Ford and all had 4 speeds in them. I had to change Hood/Hinges/Hood Latch, before he would let me continue racing that weekend. Luckly I located a steel hood/hinges/hoodlatch assembly in about 1 hour and was back racing that day. I rented them for $25 for weekend. In 1989 I was back at Indy with the car and won Class B/SA and the Eliminator, In the winners circle Travis Miller walked up to me and shook my hand and told me that he had "Researched the Ford Archives and told me that even though all the 1966 Fairlanes 427 car produced by Ford were equipped with 4 speeds......that the C6 Automatic Transmission was available to any racer who wanted one" Since then there have been many changes to satisfy different racers whims running that combo. Way too confusing the way it is now, but thats the way things are. Just my personal experiences. Thanks RJ |
