Old 07-24-2019, 11:12 AM   #1
JRyan
Liked 112 Times in 31 Posts
Default 1988 Olds Cutlass SS/NA
For sale 1988 Olds Cutlass factory give away car. multi time NHRA SS/NA national record holder. Regularly held the record since 2000. Runs 1.00+ under the index regularly in bracket mode. Capable of 1.30+ in good air.
Braced 9" ford 6.20 gear Moser axles and spool, 4-link rear suspension, Aerospace disc brakes both front and rear, Afco single adjustable coil overs on the rear, Afco double adjustable front shocks revalved by Randy Mans at Fast shocks. Full cage with swing out driver door bar, Hoosier 13.5x32.5 Radials on the rear, Mickey Thompson front wheels, Weld Alumistars on the rear, race seats w/custom interior, Aeromotive fuel, pump, Turbo Action shifter set up for air but not currently used in the car, aluminum radiator.
Engine is an Olds 307 NHRA rated at 223hp.
Sleeved 350 Olds block, 3.865 bore, forged 330 Olds crank with King spacer bearing for small journal to large journal rods, Venolia pistons, Manley rods, Bullet cam, Jesel rocker shaft system, Comp lifters, Edelbrock super victor intake reworked and filled, 800CFM Q-jet, MSD crank trigger, one off set of headers done by Tom Dawson.
Trans is a Coan T-350 with some lightened parts not the super trick trans. 2.75 low gear (15 runs) Coan converter. This is our trans and converter set up we use when we are running smaller events or bracket racing. This combination runs 11.00s in decent air.
Also available BOP pattern McClay Metric 200 fresh 0 runs 2.72 low gear, powerglide spline with 7" Coan converter which has 25 runs. $2500 This combo in good air and a gear change is capable of running 10.70s on the 12.15 index. Has gone low 90's out here in 2500-3000' air. Too many cars and not enough time to race. Buy now and qualify near the top at Indy.
Turnkey 25k
Turnkey with McClay and converter 27k
Contact either through here or call Jerry Ryan
605-225-1917 or 605-226-3167
