Old 07-08-2019, 03:07 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default valve spring pressure
350 sbc, flat tappet hydraulic cam(stocker motor) Thinking I have valve springs going causing car to not turn over 5500rpm. I used an on car spring tester. I got 110ish to just open valve and around 250ish at .500 lift(1/2" measurement), tested with that valve closed and I could spin pushrod with my fingers. Looking at Pac 1409x , it shows like 150/390. I'm thinking the springs are gone??
jamie2370 is offline   Reply With Quote
Old 07-08-2019, 04:47 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: valve spring pressure
There is a design difference between beehive and conical springs. Read this link before making your decision.
https://www.chevyhardcore.com/tech-s...sign-dynamics/
I run PAC 1427 conicals in my SBF 302 with N351 heads. They are right below the 1409s you are looking at. BB Chevy stock elim springs. They are 200/500 at 1.85 with my .597 lift cam. 6500 in the 1/8 all day.
BTW I'm solid roller all the way. If you are stock, make sure the springs you choose are allowed.
Dale Shearon
68 Mustang 6394
Old 07-08-2019, 04:51 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
What type of lifters Schubeck? or a stock type,if so are they shimmed for limited travel?.It will matter on the spring pressure you can run. gsa612
Old 07-08-2019, 06:19 PM   #4
pmrphil
Liked 345 Times in 149 Posts
Some of the on car testers vary a lot in the readings - I've had them off by 45 lbs. when checking. They should be used for reference, and the spring should be checked with a calibrated spring tester to be absolutely sure of what you have.
Phil Molski
PMR Performance
S/C 1623
