I have observed a leak from my rear main seal. The leak is occurring ,not at the seal split line, but at the bottom 6 o'clock position. Currently using a Fel Pro 2090 seal.
I've pulled the seal and it does not look worn or damaged. Is there a way to shim between the seal to tighten the clearance to the crank? Is there a better SBC main seal to use? Is there a tool to locate the 2pc rear main seal adaptor on the crank that I should be using? Any other tricks to stop the leak? Thanks in advance for the advice. Last edited by jrstock; 05-27-2019 at 08:13 PM. |
Liked 334 Times in 181 Posts
Put a thin film of rtv between the block and cap before installing the 2 halfs also rotate the seal splits about a 1/4 from horizontal and put a little dab there too--make sure the oil pan rail is FLAT so it's not pinching the seal and is making proper contact with the seal.maybe wipe a light film of oil on the seal to help on start up
Liked 239 Times in 114 Posts
What is the year of the block ? Is it a 2 pc or a 1 pc seal . Has the block been line honed ?
The block is a late model bowtie block with an adaptor to run 2 piece seal. It has been line honed.
Liked 799 Times in 236 Posts
One block I used had been line bored and the rear seal was leakage prone. Shortened the half of the seal that fits in the block until it fit normally. No offset and a dab of Valco aluminum silicone on the back of the seal and the parting lines.
We've seen a rash of rear main seal leaks lately with both the brown and blue seals.
"That'll never work....." |
#6 | |
https://allstarperformance.com/align...pter-all26127/ |
#7 | |
Liked 18 Times in 10 Posts
My issue was the crankshaft wasn't perfect where the seal would normally ride, this seal fixed it. Fel-Pro BS 11829-1 Rubber 2 piece offset double lip seal
Todd Greene |
I think he means 2909
#10 | |
