Old 05-25-2019, 07:25 PM   #1
D Janac
Default Holley conversion
Anyone out there have experience converting Ford engine controls to Holley on a 2016 CobraJet that would be willing to share information/ advise on pitfalls and issue's ? I want to keep the car as close to factory as possible. Thanks in advance!
David Janac
FSS/C 402
FS/AA 402
D Janac is offline   Reply With Quote
Old 05-26-2019, 01:26 AM   #2
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Default Re: Holley conversion
Normally when stock as possible is the goal, the thing to do is get another factory PCM to take apart and save just the header with all the connector sockets. This way all your stock harness still plugs into it, then on the side that was previously inside of the PCM you put your wires that run to the aftermarket ECU. Also usually will have some extra wires directly from the new ECU that don't attach to the OEM harness, say MAP sensor for example.
K Danner STK 468
kdanner is offline   Reply With Quote
Old 05-26-2019, 09:14 AM   #3
D Janac
Thanks Kristofer, I was hoping something like that could be done, now I just need to figure out if I am smart enough to pull it off!!
David Janac
FSS/C 402
FS/AA 402
Old 05-26-2019, 03:49 PM   #4
kdanner
kdanner's Avatar
Hey David, if not, guys like Joel: https://racespeconline.com/ and I'm sure some others out there are real artists with this sort of thing.
K Danner STK 468
Old 05-26-2019, 09:16 PM   #5
D Janac
Thanks again Kristofer, I will reach out to Joel.
David
Old 05-30-2019, 12:38 AM   #6
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
www.efisystempro.com
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 05-30-2019, 01:29 PM   #7
D Janac
Thanks a bunch for the link Darrel! I am tied up on other things today, but I will touch bases with them tomorrow.
David Janac
FSS/C 402
FS/AA 402
