Old 05-07-2019, 08:40 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default fuel rail mods?
What are the TPI and LT1 guys doing for fuel rails? Drilling and tapping for AN fittings or? More specifically the TPI setup that has a regulator between the rails. Want to remove it and replumb it different.
jamie2370 is offline   Reply With Quote
Old 05-08-2019, 08:16 AM   #2
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
Default Re: fuel rail mods?
Can't speak for the TPI but my LT1 rails have AN fittings welded to them. Each rail has an inlet and outlet.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 05-08-2019, 10:40 AM   #3
Signman
Liked 269 Times in 99 Posts
Mine are have welded AN fittings as above but there are adapters available these days. You can also use aftermarket fuel rails.
