05-01-2019, 05:08 PM | #1 |
Liked 3 Times in 2 Posts
WANTED: 8" converter to get 6300 behind 355sbc
Need good 8" converter to work with 3000 lb footbrake car. 355 sbc making 630hp / 480tq. TH350 trans w/ stock gearing. Shifting at 8000. 26x10 tire/4.30 gear for now. Will add more gear as needed.
05-01-2019, 07:07 PM | #2 |
Liked 675 Times in 267 Posts
Re: WANTED: 8" converter to get 6300 behind 355sbc
I believe I have 1 Munsinger converter that was 6100 behind 400 SBC with 400T and 4.30 gear with 30 tall tire. 10.04 at 131.5 MPH Weight was 3360. I could double check to make sure they are 8 inch but I'm in AZ. Also a Hughes 5800 in same car went 10.15 @ 130 MPH
05-01-2019, 09:08 PM | #3 |
can you get me the numbers on it? How heavy was the car?
05-06-2019, 12:48 AM | #4 |
Liked 6 Times in 2 Posts
I have a couple of 8 inch that might thr bill. Both ATIs. PM me and I'll send what ever info you want or a phone number. Thanks
Mike Semeniuk 632 GTMA |
05-07-2019, 05:48 PM | #5 |
It wont let me PM, Mike....?
05-10-2019, 11:09 PM | #6 |
let me check to see if anything came.
05-11-2019, 08:48 AM | #7 |
Liked 1,636 Times in 384 Posts
Your not gonna find and 8 inch that loose.
7 inch converter yes. Good luck
james perrone 1290 STK |
05-11-2019, 11:51 AM | #8 |
Liked 6 Times in 3 Posts
I have a 8 inch...was behind a 355. It had. 5500. Stall. Lmk if you interested. 484 877 1783
05-14-2019, 01:04 PM | #9 |
I did sell the Munsinger. The Hughes measured 9 inches on the outside and has the following numbers
C7SC+ 1/8 400 c x-5 B110 |
05-14-2019, 06:16 PM | #10 |
Casrac7
I did get your PM and sent reply, at least that's what the out box tells me. If it helps one converter was 6100 and then other was 6300 ATI inch. See if you got the PM reply. Thanks
