Liked 53 Times in 13 Posts
Built new in 2007 from a solid So. California non T.Top car... Can run NHRA,NMCA,Power Tour..Racing junk Ad # 183207871
Motor Plates for Small Block and LS ..... A New Super Stock COPO LS 396 Available ...... Currently set up for COPO LS EFI Engine Set up for Auto. also has Clutch pedal . New Profesionally wired for fuel injection with mil-spec wires and connectors front-back New lighted switch panel New Holley Dominator EFI ECU #554-114 New Holley Engine Main Harness #558-103 New Holley Coil Harness #558-321 New Holley LCD touch screen #553-106 Shows Tach,oil press,temp and control and adjust ECU/EFI function from inside the car New Dayton Sensors ( WEGO) 8 port O2 Sensors wired with the ECU Strange Coil overs all corners Strange disc brakes all corners Strange 40 spline gun drilled,lightened axles New Hoosier 11.5x30 tires M/T wheels Has brake lights,tail lights,interior lights,turn signals ( Can be a street car!! ) Power windows, Tilt Steering wheel MPR chrome moly cage 8.50 cert. MPR wheelie bar.... Much more pics available.$21,000 Rolling Call Luke 248-342-3117 Last edited by rx dealer; 04-23-2019 at 11:48 AM. |
