Old 04-06-2019, 11:59 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default Car surging? possible bad ignition box or coil?
Took our amx to the track for the first time this year with a new engine but same electronics that were working good last October including distributer and ignition box which is 7al2 and a hvh pro power coil. also same plug wires and were used and the same carburetor from last season. the car fired up and showed no signs of issues in the garage it started well and free revved just fine, so we get to the track we unload drove to tech went smooth, and being a new engine i decided to drive up the return road and see if it felt ok and with a little throttle input and load the car stumbled then spring up and stumbled bouncing the rpm from almost dead to 4000rpm so i turned around and drove back to the pits and after changing the cap rotor sparkplugs, jets , pulling the 2 step chips moving timing unplugging the crank trigger and going back to the distributor ressetting up the carb, we could not make it better. we tried to make to passes and you could ease into it and it would feel ok but fast throttle movement or to aggressive and it would stumble and start bucking again. we have a second 7al2 that were installing tomorrow to check that but i'm open to any and all suggestions.
pfordamx is offline   Reply With Quote
Old 04-07-2019, 02:25 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Car surging? possible bad ignition box or coil?
Un hook your tachometer
Adger Smith (Former SS)
Old 04-07-2019, 08:43 AM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
check the fuel,,,race fuel normally will be good for a while but you never know ,
check the voltage going to the 7A box ,,
check alternator voltage
Old 04-07-2019, 08:43 AM   #4
pfordamx
i forgot to list that but we did try unplugging the tach and it still started bucking i guess you could call it.
Old 04-07-2019, 08:47 AM   #5
pfordamx
i was curious about fuel thats one thing we did change. the car is on e85 and we always ran pump e that we mixed in the past and we swapped to a premixed with race gas e that we bought in 55 gallon drum i believe its renegade i tested it and it was 88 percent witch is fine. i didn't check check voltage at the box i'll do that today the car is on a 16 volt system and the in car volt meter was reading close to 17. oh and no alternator we just charge inbetween rounds.
Old 04-07-2019, 09:02 AM   #6
gmonde
gmonde's Avatar
you might want to investigate further on your fuel and compression of the motor ,,
Old 04-07-2019, 08:31 PM   #7
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Could be fuel pressure, needle and seat, float issue, or fuel filter.
Mike Moller
NHRA 203 Q-R-T/SA
Old 04-07-2019, 08:37 PM   #8
gmonde
gmonde's Avatar
I am thinking more on the fuel not supporting the compression of the motor ,, I ran aircraft fuel in my bracket car and it did the same thing described ,, except my motor was low compression and the oxetane was way to high and the motor stumbled at the hit ,,
Old 04-08-2019, 09:34 AM   #9
pfordamx
The motor is 14.5 to 1 what are you suggesting by not supporting i was thinking maybe too much octane and its not able to light it underload.
Old 04-08-2019, 12:31 PM   #10
RKelliher
Liked 179 Times in 58 Posts
Did you make sure the engine is grounded,since the motor was just put in. Also why are you running a e-85 mix ?.try running racing gas only. But I have seen problems with grounds.
RKelliher is offline   Reply With Quote
