Old 04-05-2019, 11:42 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Diaper question
When you have a class race and you want to cool the motor how do you drain the block if you have a diaper?
Old 04-06-2019, 12:17 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Diaper question
I've seen a bypass installed in the radiator hose that allows you to quick connect an external cooler to add to the system. Something like routing the radiator flow through a Coleman cooler full of ice water.
Commercial solutions
Ouch!!!
https://timmcamis.com/shop/chilly-wi...ne-cooler.html
Less Ouch (not by much)
https://www.sonnysracingengines.com/...down-unit.html
Dale Shearon
68 Mustang 6394
Old 04-06-2019, 08:06 AM   #3
Liked 10,852 Times in 2,254 Posts
Put hose on end of drain valve.
