Old 03-31-2019, 06:21 PM   #1
e vassar
Liked 273 Times in 109 Posts
Default Solid roller lifters for LT1
Time to make the change...any recommendations?
Old 04-01-2019, 06:41 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Solid roller lifters for LT1
Morel lifters as they are to OEM size and will fit an OEM lifter bore
I have found ISKY, COMP, Crower run to small for OEM bores.
carl hinkson is offline   Reply With Quote
Old 04-01-2019, 05:46 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
What advantages do Solid have over Hydraulic?
Old 04-01-2019, 07:31 PM   #4
bob shirley
more RPM for one
bob shirley is offline   Reply With Quote
Old 04-02-2019, 06:45 AM   #5
carl hinkson
More RPM better profiles more HP
Old 04-02-2019, 02:32 PM   #6
e vassar
The first year with this car we used nothing but Lucas 10-30 full syn racing oil. We ran out of it and decided to try Royal Purple 5-30 . We had 2 rockers come loose enough to lay over to the side just idling up to the lanes.one of the adjuster nuts was cracked. I put them back and checked all the others. At Houston the next week after a good pass, a different one came loose in the shut down area,and...the adjuster nut was cracked. So I'm thinking what was the one thing we changed?...so I fixed it again drained out the RP put on new filter.filled it with Mobil 1 10-30 raced the rest of the weekend with no problems. So I'm thinking those lifters aren't staying pumped up unless the car is screaming down the track.
Old 04-02-2019, 02:50 PM   #7
killintime6968
Liked 91 Times in 29 Posts
I don't think solid roller lifters are legal in stock.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is online now   Reply With Quote
Old 04-02-2019, 03:17 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Yes they are.
Lee Valentine 1661 STK
Old 04-02-2019, 03:47 PM   #9
This is a modern LT1 , I believe. It came with roller lifters.
Old 04-02-2019, 04:40 PM   #10
Jeff Stout
Liked 708 Times in 285 Posts
Yes on late model LT1 having roller lifters. Yes to killentime6968 on converting to solid
Jeff Stout is online now   Reply With Quote
