Old 03-14-2019, 06:42 PM   #1
t.tosto
Liked 62 Times in 23 Posts
Default Exhaust Heat Passages
What material is best to block exhaust heat passages on iron heads, SBC?Also, what is best procedure to accomplish from intake side, thanks, Tony.
t.tosto is offline   Reply With Quote
Old 03-15-2019, 08:46 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Exhaust Heat Passages
I haven't done any in a while ,but I used to use old cast pistons ,busted them up and melted in a iron pot on a turkey fryer burner . skim off the dross before pouring.
Make sure you have enough to do the fill in one pour . It helps to preheat the head casting as well to prevent the pour from shocking the casting and keeps the aluminum from chilling before the fill is complete.
I used furnace cement and chimney packing to dam the crossover in the port side and filled from the manifold side .
Be safe , take your time.
Old 03-15-2019, 12:35 PM   #3
t.tosto
thanks Tom, Tony
