Old 03-06-2019, 10:54 PM   #1
R5ROB
R5ROB's Avatar
Default SS/AM Cubic inch
Is there a ci limit for ss A modified ? Seem most are small ci
R5ROB is offline   Reply With Quote
Old 03-07-2019, 10:14 AM   #2
Billy Nees
Liked 7,866 Times in 1,750 Posts
Default Re: SS/AM Cubic inch
354 cubes. Do the math. 2650 min. wt. /7.5 lbs.per cube.
Billy Nees 1188 STK, SS
Old 03-07-2019, 10:49 AM   #3
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
I've never seen a maximum cubic inch in the rule book. The limit on cubic inch would probably be dictated by the maximum weight of the SFI chassis certification. I want to say the largest cubic inch I've seen used is 450 or so cubic inches. The reason for the smaller cubic inch engines is because most people want to be as close to the minimum weight as possible and also because most SS/AM cars are SB's as well.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 03-07-2019, 10:59 AM   #4
Chris1529
Liked 70 Times in 29 Posts
That's just the most you want to claim...right? LOL
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-07-2019, 08:53 PM   #5
R5ROB
R5ROB's Avatar
So it would be ci x 7.50 lbs and at 440 ci I would have to weigh 3,300 lbs or would I still have to add weight ?
Thanks for the reply’s
Old 03-07-2019, 09:30 PM   #6
Tracy Robbins
Liked 25 Times in 11 Posts
Your weight would be 3300 lbs if you are running a stick. Deduct 5% if you run an automatic which would make it 3135.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
