Does anybody make an auto shift C4 or C6 like they do with the metric 200?
Liked 237 Times in 126 Posts
I really doubt it. A stock C4 valve body will autoshift in D but I don't think that's what you're after. You can add an air or electric solenoid shifter to a C4/C6 stick setup, but that's very limited if not illegal in S/SS.
Liked 319 Times in 68 Posts
If anyone does it would be Dynamic in CT.
Lee Valentine 1661 STK |
Liked 372 Times in 130 Posts
PA Performance sells a C4 with the auto shift feature.
They call it their Pro Street Transmission. Not sure if they sell the valve body by itself or not http://www.performanceautomatic.com/...nsmission.html
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
I looked this one up and the VB is available for purchase stand alone and bolt in. The C4 comes in two flavors designated by year and the input shafts are different so check the part# on your trans before you do anything. This is a bit difficult to figure. The description read auto shift in D with manual on demand but the instruction download gives directions for installing a TB making it a full manual shift. Other parts of the documentation indicate auto shift for AOD.
PA makes good stuff. I use their internal TB valve body, shift solenoid and roller bearing upgrades. My roller kit included an upgraded piston for the rear solenoid because they had been seeing breakage here. It was massive. That said, documentation and customer support, not so. $420 for 65-69 C4 $320 for 70 and up $300 for C6 up to 76 I ran a TCI Street Fighter with a full manual TB valve body and 3500 stall converter on the street and towed a trailer to the strip for two years with no issues other than trans heat in heavy traffic. My advice is skip the autoshift and spare the wrath of the three pedal racers.
