Old 01-03-2019, 11:35 AM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Rod weights
Anyone know where I can find SB mopar factory rod weights? I thought that the Eagle SIR rod was legal for SB. Only CAT for stock?
House of Darts is offline   Reply With Quote
Old 01-03-2019, 01:09 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Rod weights
Log in and look up the specs for the engine you need. http://www.classracerinfo.com/
All the approved Mopar small block rods seem the same, even for a 273. SIR isn't legal and is lighter than the 755g minimum anyway. But I think they weigh the rod, piston, rings & bearings as an assembly with the minimum weights added together.
Eagle H-beam is probably the most common. Can't one polish down OEM rods to save weight? Lighter 273/318 & the standard 318/340/360 rods?
LOCOMOTION Racing
Old 01-03-2019, 01:59 PM   #3
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Rod weights
http://promod.nhra.com/userfiles/fil...edProducts.pdf
rod weight is 655 on page 15 and 16
there is only one accepted rod crs-6123 page 38
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 01-03-2019, 02:57 PM   #4
House of Darts
I've looked at those specs for some time now and never saw it. Always went directly to superseded part weight. Aren't the factory 318 rods post 1976... lighter and stronger than the older ones? I also thought that the later 318 internally balanced cast cranks lighter and stronger?
