Old 12-16-2018, 10:31 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Chevy Al 1 1/16" bore
Installing disc on front of 66 Chevy2 with drums on rear. Brake tech stated I needed 1 1/16" mc bore and 10lb residue valve for rears. I seem to remember there was a Chevy Al mc with 1 1/16" bore, but can't remember all details. Hoping someone can help my memory out. Thanks.
Ed
SS2266
Ed McLawhorn Jr. is offline   Reply With Quote
Old 12-17-2018, 01:35 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Chevy Al 1 1/16" bore
I got one from a early 80's S-10 pickup It had a flatter plastic tank on top .
Old 12-17-2018, 11:50 AM   #3
Hacksaw
Liked 310 Times in 174 Posts
Don't think anyone made an aluminium master cylinder that looks "stockish". I'm going to try a stock master from a 69 Nova on my Chevy II with the distribution block and prop. valve attached on the brackets that bolt to the mounting of the master. Won't know how it works out till next summer.
Old 12-17-2018, 02:05 PM   #4
Dave1695
Liked 15 Times in 11 Posts
Ed, is this a drag race car and is the MC mounted in stock location?
Dave1695 is offline   Reply With Quote
Old 12-17-2018, 03:58 PM   #5
Eman
Liked 133 Times in 76 Posts
Is this for a manual brake set up? For an aluminum GM master cylinder I'd look at an S-10 with manual brakes. I've used a GM MC from an early 80's fullsize pickup before but they are cast iron. Most GM aluminum master cylinders were made for power assist and the problem with them is they are made to mount at an angle, the resevoir is the problem.
I wouldn't worry about a residual ck valve unless the MC is lower than the brakes.
Old 12-17-2018, 08:43 PM   #6
Greg Barsamian
Liked 427 Times in 97 Posts
NAPA part number M2456, This might be a bolt in for what you are doing
Old 12-17-2018, 08:51 PM   #7
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Chevy Al 1 1/16" bore
The s-10 one is the way to go. bolts right up, is level and has enough volume to work with disc brake setup.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 12-17-2018, 11:48 PM   #8
Ed McLawhorn Jr.
Yes, this is a full drag car and yes the MC is mounted in the stock location.
Old 12-18-2018, 07:31 AM   #9
Todd Hoven
Guest
Posts: n/a
If you don't run the residual valve you wont have a good pedal and the rear drum brakes won't apply with the correct bias. I'd go with the Strange master that has ports set up for 3/16 brake lines. i think its 1" 1/8. That's what I installed on my Firebird and it works and fits great.
Old 12-18-2018, 10:04 AM   #10
Ed McLawhorn Jr.
Thanks Todd. I can use the 1 1/8" MC. The strange looks like the ticket and priced very reasonable.
