Liked 53 Times in 17 Posts
Ok, your thoughts? SS 327-275hp 3rd gen Camaro, 1 7/8 no step or 1 3/4-1 7/8 - 2in 3 step/ Both with merge collectors. Running in fair to bad air all season. Better set?
Liked 7,941 Times in 1,520 Posts
Liked 310 Times in 174 Posts
Step is the way to go
Liked 370 Times in 101 Posts
Does Ben have a phone number ?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 1,937 Times in 582 Posts
I have 1 7/8 straight with 3.5 inch collectors on my 327 275/295 combo running SS/IA. Runs Ok but I think a smaller header would help. 1 3/4 step would most likely be better. Maybe even 1 5/8.
Mike Pearson 2485 SS |
Liked 7,768 Times in 1,741 Posts
You might as well be talking about sax and politics!
Liked 759 Times in 379 Posts
no maybe definitely! Most run headers that are not one but two pipe sizes too big.
Liked 99 Times in 49 Posts
Mike on my 327 250 hp i have 15/8 13/4 3 " I tryed 13/4 to 1 7/8 3.5 moved peak power up but lost 10. I think 1 3/4 1 7/8 with 3 1/4 collector. my 250 is the small valve eng.
Mike, I have a set of coated Hedman Hustlers that we put a set of Stahl flanges for my SS HeadsUp! heads, that are 1 3/4"-1 7/8" steps you can try & buy if you like them. My LT1 much prefers 1 7/8" no-steps. I started with 1 7/8" Hedman on my 383" street/race engine. More power & faster than my SS 350". All my SS friends around here told me I needed step headers. The 1 7/8" Hedmans hit the ground on hard landings, and hung up backing out of the trailer, needed tucked up closer to the floor of the car. The steps slowed my SS 350" down. I learned Jere Stahl made headers for our model now. Always used Stahl's on my old race cars. Got to know him back then, when the NHRA World Finals were run here at Tulsa. I called Jere, he wanted dyno sheets & time slips. Sent all that. He calls me to tell me "Your car does not want step headers". I had not told him what I found testing them. He had started building steps at that time. I saw so many around here with them, guess my old mind thought that was the new thing I needed. Back-to-backed them, same day, at the track, then thinking it needed tuned differently, a day on the dyno.
Jere said it MIGHT like 1 7/8"-2" steps, but kinda doubted it. Won't say why I no longer have the 1 7/8" Stahl's, but they certainly were faster than the steps I tested. Ditto "Merge collectors", more wasted money testing that. Not all SS cars like the same thing. Different cylinder head shops & different cams, etc. if your header plates have the Stahl bolt pattern, I can send you these Hedman 1 3/4"-1 7/8" steps. Have to use your own collectors. Could save you wasting money like I did. I could meet you somewhere with them, or ship them. Maybe your 327" will like them.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-02-2018 at 07:01 PM. |
How did you come up with that? Do you not realize most Stock & Super Stock racers actually test these things? Unlike bracket most racers. I have seen many EFI cars like larger tubes than carbureted engines. Mine is enough faster with 1 7/8" than 1 3/4" (including 13/4"-1 7/8" steps) , I am not too sure it would not like 2" headers in good air.
Ed Wright 4156 SS/JA |
