Old 11-17-2018, 12:18 AM   #1
doug schriener
Liked 7 Times in 6 Posts
Default chev 4-7 firing order change
Hi-This may have been talked about here;if so indulge me-what is the purpose in changing the firing order? Is it because 5 and 7 fire close together? Does it make more power or show a difference in cooling? Thanks for all answers. Doug Schriener
doug schriener is offline   Reply With Quote
Old 11-17-2018, 05:05 PM   #2
1720
1720's Avatar
Liked 2 Times in 1 Post
Default Re: chev 4-7 firing order change
http://garage.grumpysperformance.com...cam-swap.5508/
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 11-17-2018, 09:38 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Read the link. The same goes for using a 351 firing order on a 302 Ford where 7 and 8 fire in sequence. It can take some of the stress off the crank. You need to use a cam that matches the firing order, though. I tried just moving the wires and it wouldn't fire...
Dale Shearon
68 Mustang 6394
Old 11-19-2018, 09:19 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Big Cu.In. Hi HP Chevy engines will usually kill the # 4 main if the firing order is not altered. It can also smooth some of the pulses out in the intake manifold, too. The first altered firing order cam I used came from Lunati back in the early 70's. Some guy named Chris told me I needed it.
Draw out the firing order across the intake plenum to see where the air goes as well as the power pulses hit the crank.
Adger Smith (Former SS)
Old 11-21-2018, 01:12 PM   #5
Ed Wright
Ed Wright's Avatar
When I was running (NOT driving!) a 410" "outlaw" dirt track sprint car in the '80s, the 4-7 firing order swap improved my bearing life. Did not test that on a dyno. All I had was a chassis dyno.
Ed Wright 4156 SS/JA
Old 11-21-2018, 04:09 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,903 Times in 571 Posts
I have 3 engines. all have different firing orders. One is standard. one is 47 swap. One is 47-32 swap. All seem to run the same. don't see any real difference the way they run of idle. more of a gimmick in my opinion. all Bullet cams too.
Mike Pearson 2485 SS
Old 11-21-2018, 05:11 PM   #7
MR DERBY CITY
Liked 7,792 Times in 1,496 Posts
I changed the plug wires for the 4 -7 firing order years ago. The ole wagon ran rougher than hell and would barely drive onto the trailer....
Old 11-21-2018, 06:07 PM   #8
Bill Grubbs
Liked 564 Times in 66 Posts
MJ, your problem was changing just the plug wires...you also have to change the sparkplugs.
Speaking of firing order... We did have a problem the first time we tried to dyno a set of Elston Tri-y's. They would not fit as the dyno cradle was too wide. The dyno operator said no problem we'll just swap sides and turn them upside down, like a boat header. I told him I did not think it would work.
Well...it did not work. In fact it did not work so well that the engine would not even start!!!
Bill Grubbs is offline   Reply With Quote
Old 11-22-2018, 10:14 PM   #9
SSDiv6
Liked 1,538 Times in 575 Posts
There is more than swapping the camshaft and spark plug wires involved in the firing order swap.
Many times the engine will not pick up power due to the intake type used, dual plane versus single plane and it may require a change on the location of each header tube at the collector.
Here is a good article that addresses the subject:
https://www.enginelabs.com/engine-te...r-your-engine/
Old 11-23-2018, 05:12 PM   #10
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
For the record, that was NOT me!
Pedigo Perf is offline   Reply With Quote
