Old 11-11-2018, 10:45 AM   #1
jimi
Liked 21 Times in 8 Posts
Default 1969 cuda unfinished stocker build.
I have an original 69 cuda formula “s” that was being built for stock eliminator, car is an original 340 formula s 4 speed . Car has mild steel 10 point roll cage installed body is in primer. Car is a barn find that was sitting in storage for over 30 years prior to starting build. Car had very little rust. A new trunk floor was installed (original was modified poorly) prior to installing roll cage. The car is sitting covered on a trailer with no rolling gear to keep items from rusting or getting dirty while sitting. Complete body is assembled.
Car comes with ,
Complete 8 3/4 rear, back braced,4:89 gears, 742 carrier with Williams caps, strange spool, Mark Williams axles 5/8 studs ,weld wheels Hoosier radials. TRI city launcher springs.
Front suspension is all new components,poly bushings fitted for minimum drag , NIB wilwood front disc brake set. Do not have front wheels.
I have most of factory wiring, chrome trim, weather stripping. Brand new wind shield. All glass is present.
Project is missing a fair amount of interior parts. I do have door panels and seats, interior / trunk divider, dash board and steering column.
Asking $12,000 for everything, will consider selling trailer it is being stored on as well for easy shipping.
Also have a 383” “69” engine that was being built for this car for sale.
Engine has the best parts will consider making a package deal.
Please call or text 845-298-9041 for pictures or more info.
