Liked 25 Times in 9 Posts
Is there a formula when going from conventional collector's to a merge in reference to shortening the primary tube by how much to start on a 1 5/8" x 33" on a 4-1 header low HP Low RPM V8 - Thank's in advance any input is appreciated
Liked 2,487 Times in 698 Posts
We do not change primary length.
Ok I have been told bye a reputable Header Mfg that they should be shortened to take full advantage of the collector and I just didn't know how much but thank you for the response - John DID YOU find an improvement and if so immediately or did you make other changes as well - Thanks Bob
I’d recommend calling Mark Lelchook of Performance Welding. Based on your combination and current header he can get you pretty close. Highly recommend buying the collectors from him, they are a pure work of art.
TY - I look him up
I found 3 to 4 hundreds without any other changes
Liked 358 Times in 83 Posts
Larry Meaux.PipeMax. Best money you'll ever spend, if you're buying expensive headers and collectors because you're serious about power.
Alan Roehrich 212A G/S |
Liked 804 Times in 341 Posts
I wanted to put mine on the a coffee table rather than the race car. Great work!
Liked 780 Times in 194 Posts
X2!
