Liked 70 Times in 31 Posts
Is anyone using Turbo Blue 110 in Stock? It use to be on the approved list but it's not on their now. Do they not allow it now? Thanks.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
Liked 237 Times in 127 Posts
Only Turbo Blue Extreme 116 is still in the List. I run pump gas, but that sounds a bit stiff for stock. Not on the List means no. Fuel is determined by chemistry and you can't argue around that.
Thanks Dale. I wonder why they'd remove it? I may try pump gas although I won't be able to run that at divisionals or nationals I'm assuming.
