Liked 38 Times in 13 Posts
Would someone who has used hydraulic fluid in their automatic transmissions be willing to share the advantages and/or disadvantages to using it over regular ATF. - Thanks!!
Larry Peterson Stk: 6261 B/SA ![]() |
I can not imagine what the advantage would be. Sure be interesting to hear.
Ed Wright 4156 SS/JA |
Liked 341 Times in 67 Posts
It is more consistent from run to run. We use John Deere 303
Liked 485 Times in 160 Posts
I recall reading numerous posts about this on YB many years ago.
Liked 99 Times in 60 Posts
a respected/experienced converter builder tells me it "tightens" the converter 200 RPM. After some experimentation, I have settled on name brand Dexron/Mercon III. [that is to say, not a house brand] Valvoline, Pennzoil, Castrol, etc. The house brands, while OK for basic passenger car service, do not have the premium additive package to resist heat over time.
Larry Woodfin 471W |
Liked 172 Times in 81 Posts
The specific gravity of the fluid will have more influence on the stall speed than the viscosity. Synthetic fluids change viscosity less with temperature than dyno fluids so will be more consistent, look for a fluid built with group 4 base stock.
Confusing, yes, I do this stuff for a living. Jim Mantle V/SA 6632 |
A friend of mine here in gonzales la been running that !!! Keith hunter w powertrain specialist !!!! Works gd !!! Js
Liked 425 Times in 51 Posts
I long time friend and serious bracket racer who owns a trans shop told me it does run a little more consistAnt but if you get into close back to back runs it doesn't stay as cool as regular trans fluid
Liked 373 Times in 131 Posts
I run the John Deere Hygard fluid in mine ( $ 17 a gallon)
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 708 Times in 285 Posts
I understood in using it to tighten a N/A converter that gets nitrous applied to it. With nitrous a converter becomes way to loose and with the hydraulic oil it will bring it back 3-400 rpm's
