Old 09-27-2018, 01:40 PM   #1
terry1
Liked 24 Times in 13 Posts
Smile Auto Meter 6896
Has anyone had any experience with the
Auto Meter Ultimate play back tach model #
6896.I am looking for a simple, but effective, way
to monitor my engine RPM vs drive shaft RPM.
Terry K
terry1 is offline   Reply With Quote
Old 09-27-2018, 02:01 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Auto Meter 6896
What I do is make a run , then make a change , and compare the two runs by overlaying the traces . Typically if you can make areas of the driveshaft rpm get faster at a particular time stamp (acceleration) , then you have found an improvement .
Old 09-27-2018, 02:21 PM   #3
Mark Howes
Liked 80 Times in 28 Posts
Good Unit for the Money. Also allows for a PSI sensor.
Mark Howes is offline   Reply With Quote
Old 09-27-2018, 02:30 PM   #4
terry1
Smile Re: Auto Meter 6896
Thanks Mark for the reply.
"ss3011", are you using a 6896 unit?
TK
Old 09-27-2018, 03:45 PM   #5
ss3011
ss3011's Avatar
Ultimate II , I believe it uses similar software , but the 6896 allows data log of O2 sensors , pressures , etc. Comparing driveshaft rpm should be a valid way of determining improvements .
