Old 09-25-2018, 08:48 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile how often should u change oil on a stocker
sb Chev auto trans. Would 4 litres of oil in the pan be enough, we spun two rear rod bearings, surely 4 L is enough ???
Mike Savelle is offline   Reply With Quote
Old 09-25-2018, 11:31 AM   #2
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
Default Re: how often should u change oil on a stocker
25 to 30 runs on synthetic
Knock wood, everything looks just as good as when it goes together
Frank
F Federico
NHRA J/SA
dragracer502 is offline   Reply With Quote
Old 09-25-2018, 01:00 PM   #3
Rory McNeil
My 302 Ford was not a real high RPM piece, but I would change the oil once a season, and everything always looked great when it was time to freshen up. Bear in mind, I did not normally run the ultra thin "magic oils" that many do, I would run Brad Penn 10-30 semi synthetic. I use the same oil in my low 10 second bracket car, and again run the same oil all year. Now, for me, a full season is usually only 60-80 passes, if you run a lot more races , and go a lot more rounds, thats a different story.
NHRA 6390 STK
M/S 85 Mustang
Old 09-26-2018, 05:42 PM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Every second race for me. Oil's cheap. Engines aren't. Plus I don't run a filter. One less thing to worry about. Six S/S years - no problems.
Bruce Fulper is offline   Reply With Quote
Old 09-26-2018, 07:18 PM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Lack of oil would cause number 1 and 2 to spin before number 7 and 8 (rear) unless something else is wrong in my experience on a small block Chev. I ran a SS/IA 68 Camaro for several years and never had a problem. Used the same engine in a tube chassis old SRD Pro car Pont. Astre before I stopped racing. Turned it to around 7700 RPM on the shift and in the lights with OEM rods.
Old 09-27-2018, 07:00 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Why would you think this??????
Do you have a data logger because it takes hundreds of readings every second to confirm what your oil pressure actually is???
Mechanical oil pressure gauges use an orifice (jet) to dampen the gauge response and can lead to undiagnosed low oil pressure.
4 liters (4.2 quarts) might not be enough oil if you are using a 1 quart oil filter....
Do you run 4 liters of oil all of the time?????
Why not baffle the pan and add another liter or 2???
It could starve on acceleration or de-acceleration....
Oil is cheap insurance...
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 09-28-2018, 08:21 AM   #7
Mike Savelle
Post Re: how often should u change oil on a stocker
I want to know what happened so it doesn't happen again .
no data logger
never seen low pressure on launch, it fluctuates on top end even though we have a trap door .
4 litres in pan and one in filter
usually run 4 litres
there is a baffle under the pump and the trap door
I will be adding more oil
I run a stock pump, should I run a HV , that would empty the pan even quicker or not ?
perhaps the rods have too many passes.
just trying to correct what happened , thanks for any advise .
Old 09-30-2018, 06:57 AM   #8
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Question Re: how often should u change oil on a stocker
What weight oil and any screens in lifter gallery. What about detonation hammering rods?
The more people I meet the more I like my dog
Kevin
Old 09-30-2018, 08:07 AM   #9
Mike Savelle
Kevin , also the drain backs beside the lifters are plugged ,5 w 30 semi synthetic and yes screens in the valley......
Old 09-30-2018, 09:00 AM   #10
Mark Lewis
Liked 207 Times in 44 Posts
If you have those drains plugged then it might be trapping too much oil in the top if you don,t have it vented some how. Ran into this years ago
Mark Lewis is online now   Reply With Quote
