Old 09-18-2018, 11:51 PM   #1
nhrasa
Liked 95 Times in 12 Posts
Default What header size
I'am turning my 63 Plymouth max wedge bracket car into a class car. I was wondering if TTI 1/78inch mild steel headers would be adequate or do I need to switch to a larger diameter stainless steel header from one of the current header builders. Thanks for the responses in advance.
nhrasa is offline   Reply With Quote
Old 09-19-2018, 06:35 AM   #2
rod butcher
Liked 129 Times in 24 Posts
Default Re: What header size
Call Performance Welding Headers 530-367-4124 Best header guy in the business, the Indy qualifying sheet doesn't lie.
rod butcher is offline   Reply With Quote
Old 09-19-2018, 07:09 AM   #3
nhramnl
Liked 352 Times in 82 Posts
Try this explanation instead: "I'm turning myself, currently a sane, solvent individual who has a great deal of fun bracket racing, into an insane, insolvent maniac, who will pour seemingly endless amounts of money into a car that will never be quite fast enough for me, and which I will only on very few occasions, actually enjoy". Now we can all relate to what you're asking, because you've identified yourself as one of us.
Old 09-19-2018, 07:53 AM   #4
jmcarter
jmcarter's Avatar
Liked 2,707 Times in 853 Posts
xxx double posted
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-19-2018, 07:57 AM   #5
jmcarter
jmcarter's Avatar
X2. Mark Lelchook is a absolute master craftsman. Based on his experience he can tell you power curve on different styles and diameters. Guarantee his stuff will fit too.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-19-2018, 09:41 AM   #6
quickford1
Liked 18 Times in 10 Posts
Give Robbie McDonald a call @ outlaw headers 704-230-6429 located in Mooresville ,NC Does only stainless makes everything in house flanges,tube bending and the best collector out there.
quickford1 is offline   Reply With Quote
Old 09-21-2018, 07:13 AM   #7
Race Clean
Liked 129 Times in 51 Posts
I think this may be an answer along the way that you want :
For what you are trying to do it's probably a good way to start with TTI or similar priced Headers and spend the $2500 that you save on other things to make the Car faster and better,..that said....I already have 2 sets from Mark and may buy another set in the future, because I REALLY LIKE this type of ART!!!
Race Clean is offline   Reply With Quote
Old 09-21-2018, 07:39 AM   #8
RonP
Liked 24 Times in 11 Posts
Smile Re: What header size
I would try KromerKaft in Youngstown, OH (330-539-5053). Engine size and expected peak HP rpm are required to determine tube size and length. When it comes to Stock/Super Stock/Comp, the header needs tailored to the specific engine. I used to do most all the computer simulation for Kromer to determine header sizing back in the late 1990's & early 2000's . Mild steel + GOOD ceramic coating (inside & outside) will save you money over stainless.
Thanks, Ron
RonP is offline   Reply With Quote
Old 09-21-2018, 11:31 PM   #9
pfordamx
Liked 7 Times in 5 Posts
i've heard several people have had good results with REF unlimited in arizona. if you buy a shelf header you might look into a program like pipemax to help determine primary size.
pfordamx is offline   Reply With Quote
Old 09-22-2018, 02:39 AM   #10
GTX JOHN
Liked 1,809 Times in 572 Posts
I have raced a bunch of these cars.
At least 2 inch tubes = Hooker has made Thousands and they
are cheap used. Even their 2 x 32 street header is fine.
2 1/8 inch are marginally faster on a quicker car.
Steps/Merged are certainly a bit better = Cost is three
Thousand VS three or four Hundred bucks
I have several sets of Hookers laying around the shop (Clarification: The Headers
NOT the girls).
John Irving
741 Stock
741 Super Stock
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
