Old 09-04-2018, 03:38 PM   #1
68Coupe
Default question about vehicle
My car is not back halfed but it does have S&W ladder bars with coil springs. it isn't a stocker only a bracket car. i have a lot of front end travel.
at my home track the roll out is really loose and i have a hard time cutting a light. i have already adjusted air pressure and staging RPM.
i was just wondering if you move the ladder bars front hole up, would that make the car react any faster. just looking for any ideas to help the car react faster at this point.
68Coupe is offline   Reply With Quote
Old 09-04-2018, 03:48 PM   #2
Rory McNeil
Default Re: question about vehicle
I would be looking more into shorter front tires and/or cutting down on some of that front end travel.
NHRA 6390 STK
M/S 85 Mustang
Old 09-04-2018, 05:58 PM   #3
Hacksaw
Liked 311 Times in 175 Posts
Changing the front pick up point on a ladder bar car is a touchy subject here on this forum with several theories flying around. IMO, yes to moving up one hole to quicken your rt time. However the improvement will probably be minimal and your car may turn into a wheel standing animal. You need to test this and evaluate. A smaller front tire is the easiest fix. Next, trans brake, MRT converter, more 1st gear in the trans, shorter rear tires, more rear gear, camshaft change to provide more torque. and the list goes on.
Old 09-04-2018, 11:26 PM   #4
BWill
The quickest and most simple IMHO is front end limiters. I race at multiple tracks in my area, and I have set ups for each track.
BWill is offline   Reply With Quote
Old 09-05-2018, 10:58 PM   #5
Eman
Liked 133 Times in 76 Posts
Can you deep stage?
