Old 08-12-2018, 07:49 PM   #1
Wayne Scraba
Liked 196 Times in 49 Posts
Smile Nova with Long V Gate Shifter
Hi. I'm building a 1970 Nova as a "for fun" car. The plan is to use a G Force G101A transmission along with a Long V Gate style shifter. I'm using BBC engine and trans mounts that shove everything over 1/2-inch or so to the passenger side. I know a big hole will be needed for the shifter, but does the side of the tunnel have to be cut away for the shift rods too? If you've done a '68-72 Nova, can you let me know what was required and maybe share some photos?
Thanks!
Wayne
Wayne Scraba is offline   Reply With Quote
Old 08-12-2018, 08:00 PM   #2
Nmbr1GMfan
Default Re: Nova with Long V Gate Shifter
'76 nova small block Jerico, shifter at the rear of tailhousing.
Todd Greene
Old 08-12-2018, 08:31 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
Yes you will have to cut most of the drivers side of the tunnel out. I had to in my 68 Camaro
Mike Pearson 2485 SS
Old 08-12-2018, 08:59 PM   #4
Wayne Scraba
Smile Re: Nova with Long V Gate Shifter
Thanks Mike. Was yours a small block or big block application with the offset?
The '76 Nova that Todd posted has a different floor pan than the '68-72 ('73 and '74 too I'm guessing) cars. But thanks anyway Todd.
Wayne
Old 08-13-2018, 10:43 AM   #5
Mike Pearson
Small block with standard mounts. I had the engine pushed as far as the headers would allow to the passenger side.
Old 08-13-2018, 10:59 AM   #6
Wayne Scraba
Thanks Mike! I appreciate it.
Wayne
Old 08-13-2018, 08:56 PM   #7
BILL TAYLOR
Liked 200 Times in 62 Posts
Wayne
When I put my Jerico in my '69 camaro 396, I had to make a little tunnel for the 3-4 shift rod. Now that I'm running a G-force, the extra clearance was needed also. You may have more of the tunnel cut-out than I did, but the 3-4 rod goes past there as you know. Bill Taylor.
BILL TAYLOR is offline   Reply With Quote
Old 08-13-2018, 09:21 PM   #8
Wayne Scraba
Thanks a bunch Bill. This is the stuff I needed to know.
Wayne
Old 08-14-2018, 12:47 AM   #9
Rory McNeil
Not a Nova, but when I put Jerico DR4s and Long V gate shifters in my 78 Ford Fairmont and 85 Mustang, I sliced the top of the trans tunnels , near where the drivers side of the tunnel meets the top, bend the side wall straight up enough to clear the shifter linkage, and then welded in a strip along the top to fill in the gap, which in my case, was about 3 1/2 " wide. That said,an ealry FOX body Ford has a fairly narrow trans tunnel to start with, as the only manual transmissions available were internal rail shifter models, or a C4, with the AOD coming out in the mid 80s.Since a 70 Nova could have had a TH400 or Muncie with external shifter linkage, the tunnel is wider, but appears lower in height than the FOX body. Regardless, the side of the tunnel will need quite a bit of room for the high mounted shifter box unit.
Wayne, are you coming to Mission in 2 weeks for the "Smoke Fire & Thunder " race? If so, our stick group has races both days, so you could check out some trans tunnels there. Not sure if they are the same, but one of our guys has a 77 Camaro with a G101A and Long V Gate shifter.
NHRA 6390 STK
M/S 85 Mustang
Old 08-14-2018, 01:29 AM   #10
Dissident
Liked 73 Times in 36 Posts
Howdy Wayne,
FWIW -
Don't have measurements on Long stuff albeit Cadillac equipment,
but a Hurst/Mr. Gasket V-gate shifter mechanism measures 7" long x 4" high x about 1" thick. That is the shifter mechanism only and does not include any bracket to bolt to transmission.
Good luck on your build old buddy.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
