Old 08-12-2018, 06:14 PM   #1
Nmbr1GMfan
Default Axle weight?
Is this a lot? 33 spline 12 bolt.
Todd Greene
Old 08-12-2018, 07:33 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Axle weight?
I know people who had axles "rifle drilled" to lighten them, and saw zero E.T. changes.
Un-sprung weight is not as desirable as weight suspended, or "sprung-weight", I am told.
Weight changes on larger diameter components would be more noticeable due to effects on inertia.
Lighter axles, as I have been told, "can't hurt a thing."
I have some very bright friends. Wish I knew everything they know.
Ed Wright 4156 SS/JA
Old 08-12-2018, 07:55 PM   #3
Nmbr1GMfan
These things just seem awful heavy, I may have to call an axle company tomorrow to check weights.
Todd Greene
Old 08-12-2018, 07:58 PM   #4
MR DERBY CITY
Liked 8,046 Times in 1,527 Posts
When you are running a stick shift, Sooner or Later.....You will purchase Mark Williams axles....They weigh what they weigh.....
Old 08-12-2018, 10:01 PM   #5
David Lee
Liked 346 Times in 126 Posts
that is in 1/10 of a pound of my moser's . so it right in line.
Old 08-12-2018, 10:10 PM   #6
FED 387
Liked 333 Times in 180 Posts
Rifle drilling and scalloped flanges will result in a 17-25% weight reduction over a non lightened axle--- also keep in mind that a one pound reduction in axle weight is like a 15-17 pound weight reduction that the engine sees it has to try to overcome--FED 387
Old 08-13-2018, 06:53 PM   #7
Nmbr1GMfan
Thanks for the replies guys. I did call Strange today and in order for them to get me a side by side comparison they need the length of my axle, I'll get it and try to call back tomorrow.
Todd Greene
Old 08-13-2018, 07:01 PM   #8
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Sounds like quite a bit, curious how you arrive at those amounts?
Mike Moller
NHRA 203 Q-R-T/SA
Old 08-13-2018, 07:35 PM   #9
Nmbr1GMfan
Mike, I found lots of info on this subject, as I've been looking. This particular article states that a Mark Williams superlite axle is 8lbs lighter than mine, thats a 16lb difference in axles! Seems like a lot to me.
https://www.markwilliams.com/aerp3.html
Todd Greene
Old 08-13-2018, 07:43 PM   #10
FED 387
A cubic inch of steel weighs .283 pounds plus add in all the material in the flange multiply that by 2 and you get a number probably about 4-6pounds per side depending on axle length and diameter
