07-24-2018, 08:14 AM | #1 |
Liked 14 Times in 4 Posts
trend lifters
Hi all i am working on a stock eliminator pontiac 455 engine here in sweden with a bullet billet cam and trend hydraulic dlc coated lifters manton restricted pushrods (restriction 0.032) and still getting to much oil in the valvecovers how small restrictions can i use . regards magnus
07-24-2018, 09:25 AM | #2 |
Liked 232 Times in 57 Posts
Re: trend lifters
When I was using the Trend lifters in my 327 Chevy, I bought pushrod cups from Trend with .014 holes and it oiled just right. Didn't have restricted pushrods. The last set of Trends I bought were ordered with the .014 holes, but measured .029 and over-oiled the top end. Hope this helps.
07-24-2018, 09:40 AM | #3 |
Liked 770 Times in 230 Posts
Re: trend lifters
My Trends have the .014 oil hole in the cup to restrict the oil flow....works great.
I did have to shim the cup to eliminate all movement. The reduced oil hole diameter allowed too much oil to stay in the lifter, raising the cup and holding the valves open as RPM increased. This has as more do with the block (raised lifter bores) and lifter clearance (.0015) than the lifters. I know several others that used the .014 cups with no issues in stock blocks and/or those with a bit looser lifter clearance.-Al
"That'll never work....." Last edited by Alan Nyhus; 07-24-2018 at 09:44 AM. |
07-24-2018, 11:17 PM | #4 |
Liked 3 Times in 2 Posts
Re: trend lifters
Had to use the .014 cups in my flat tappet trends also, Cleveland with non restricted pushrods.
Cheers Paul |
07-25-2018, 03:29 PM | #5 |
Liked 720 Times in 151 Posts
Re: trend lifters
For a Pontiac I would just tap the block for lifter bore restrictors. 1/4 20 tap fits in the existing holes that feed the lifters inside the lifter bores. Then use brass set screws and go with a .016 to .018 drill to make the holes. That should slow the oil down
Todd Hoven 1035 Stock |
07-26-2018, 03:04 PM | #6 |
Re: trend lifters
thanks for the answers i restricted the pushrods to 0.014 and now it works fine. Todd are you going to us nationals i talk to you there last year maybe i see you there. regards magnus
