07-21-2018, 04:40 PM | #1 |
Liked 20 Times in 15 Posts
Mopar tq rebuild
How do you like to rebuild, stock parts/strip kit or revamp with Holley jets?
07-23-2018, 12:48 PM | #2 |
Liked 234 Times in 63 Posts
Re: Mopar tq rebuild
I would use stock parts.
John Dinkel 3295 STK |
07-23-2018, 02:38 PM | #3 |
Liked 94 Times in 24 Posts
I think your fishing for an easy answer. I would say, spend the money (three hundred plus dollars each) and have good builder do three carbs for you. then you can compare the carbs back to back. I could tell you which one picked my car up a tenth, but that would give you our answer. Spend the dollars and do some research on your combination.
07-23-2018, 07:31 PM | #4 | |
Liked 389 Times in 168 Posts
Ed Wright 4156 SS/JA |
07-23-2018, 10:39 PM | #5 |
I'm sure others might be more willing to share but there are two reasons not to just give an answer. First when it costs you that or more, you aren't very willing to just give that info out. Second and more importantly like was mentioned, you need to try different setups on your combo. One size does not fit all especially at varying elevations because I can guarantee they will behave differently.
5705 F/S 5706 D/SA |
07-23-2018, 10:42 PM | #6 |
Liked 2,774 Times in 868 Posts
What Ed said....but know that you may have to try more than one to get the best. They simply do not all perform the same even with same Holley jets or the rods. Have used both VanLant and Wahl with success.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock |
07-24-2018, 12:15 AM | #7 |
Liked 49 Times in 34 Posts
A shame but what they're saying, learn to do it yourself or have a big wallet.
Mike |
07-24-2018, 06:46 AM | #8 | |
Liked 21 Times in 13 Posts
What exactly are you suggesting ? 1 builder do the same model carb 3 different ways, or use 3 different builders ?
Brian Carpenter Stock 1358 |
07-24-2018, 08:23 AM | #9 |
Liked 278 Times in 153 Posts
Carb builders get comfortable with their own setup and it's unlikely they would build the same style carb 3 different ways. IMO you should gather info and order one built to suit your combo from " the brand name guy " then later after your making laps you can try another one, then another one, and then............
07-24-2018, 09:31 AM | #10 |
That makes sense. It would be cool to see dyno testing using different center bodies(thinking holleys here) and the same mods. Probably classified info though
