Liked 7 Times in 5 Posts
I know for a large number of you guys hood scoops are illegal, but maybe some of you gt guys can chime in, what hood scoop designs have you found to be most effective. or is it basically just staying away from the top of the carb, we did a test last week and picked up a tenth and a half by running with out a hood. we have the traditional SS amx scoop on our car and its about 2 inch above the carb and the carb is sealed to the hood. we were considering having another one made that was 3 inchs taller but the same style to maintain the look kinda like the exaggerated max wedge scoops but i'm open to suggestions.
Liked 880 Times in 311 Posts
PM me your E-mail and I will send you a program that lets you figure scoop size needed. you only need what you need, no more..
Adger Smith (Former SS) |
Liked 885 Times in 238 Posts
As Adger said opening size is very important .
Height of the scoop is very important also in allowing air flow to" straighten out" ,so to speak. I found significant gains in this area over the years on my and customers cars. Also the larger the scoop the more areo drag Years ago I had a SS/AMX type scoop on my Modified/Production Javelin , the car picked up a tenth by turning the scoop backwards .
Liked 115 Times in 35 Posts
The 69 nova I ran in ss/as with a big block years ago we started with a snorkel scoop popular in the 80's. We fought that car for a year changing fuel and ignition parts until someone suggested removing the air pan sealing the carb to the scoop. With the scoop sealed to the carb it would just nose over at about 1000'. After removing the air pan the car ran fine and picked up a bunch.
Had a couple different scoops after that but never saw any gains sealed up. We just ran it open under the scoop. My 67 camaro with a big super mod type scoop on it worked ok sealed to the carb unless there was a cross wind and then it had problems. |
Sounds like there's alot of good experience and knowlodge on this topic. i've been looking at one of the shorter round snorkels like you see on some of the front wheel conversions or there's a guy with a white early camaro running modified stock with a round scoop i don't his name though but i'd like to try something like that.
Liked 33 Times in 17 Posts
Get one just big enough to do the job. Too big of one and you end up running over cones and trash cans. Wish i didn't have one on mine.
#7 | |
Liked 100 Times in 51 Posts
Dan
Dan Foley SC 4698 |
thats an interesting thought we are adding a belly pan and front spoiler/air damn, do you think those things will help that problem i figured it was turbulence above the carb we could always remove the scoop and leave the hood and see what that does.
Liked 281 Times in 145 Posts
Get a long piece of yarn or thin rope, tape the beginning of it to the very front edge of the hood, and the other end to the edge of the front of the roof. If the scoop opening is not above/in front of that line you just created, the scoop is not working effectively. The exception to this rule is a NACA duct laid into the hood. Air flows over the hood, and along the very top of the hood. That is from the old Direct Connection bulletins.
