Go Back   CLASS RACER FORUM > Stock/Super Stock Associations > IHRA Pure Stock Challenge
Old 06-25-2018, 05:15 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Pure Stock Update
Made a few changes to my car this last month.
Installed updated heads.
Better Valves, Springs (120# Seat) and 7/16 Rocker Studs.
Thank you Chuck Norton for sending modified LT1 Stock Rockers to fit over the larger Studs.
Made a few tuning changes to the PCM, fixed exhaust leaks.
Worked on the Brakes.
Emergency Brake Cable was not returning.
Causing the Emergency Brakes to squeak from dragging.
Serviced the Front and Rear Disk Brakes.
Car rolls a whole lot easier.
Few other updates, suspension change, a good cleaning.
Ordered new Micky Thompson Front Runner and Bracket Radial Slicks.
Ran at Mason Dixon and later at Island Dragway.
The car picked up a good bit even in the heat.
Next quest having a Roll Bar Installed.
After that, a Full up 8.5 inch rear, 9 Inch Ends and better Axles.
Safety first …!
Then the new Cam and Springs.
Next year should be a full up K/SA Stocker
Dan
Old 06-26-2018, 07:04 AM   #2
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default Re: Pure Stock Update
Congrats on the improvements.
Mitch Beri- The Motor City
