Old 04-29-2018, 04:57 PM   #1
randy wilson
Liked 22 Times in 22 Posts
Default 302 Z-28 engine only
I may have a barn find. Says 302 on the air cleaner that was left on the engine after they robbed the carburetor. The intake is correct, and looks legit. Need to get inside of it, and take a peek. What’s one worth if I completely rebuild it to exact specs?
don,t have one
Old 04-29-2018, 06:54 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: 302 Z-28 engine only
If you can find the Z28 that it came out of, it'll be worth big bucks.
Other than that, if it's a 69, it's an 010 block with a 3" stroke crank and decent heads. JMO
Chevy55 is offline   Reply With Quote
Old 04-29-2018, 06:59 PM   #3
BillK
Liked 30 Times in 17 Posts
Randy,
Call or email Jerry:
http://z28camaro.com/
Bill Koustenis
BillK is offline   Reply With Quote
Old 04-29-2018, 07:21 PM   #4
randy wilson
Originally Posted by BillK View Post
Randy,
Will do. The thing is I run a small construction company, and one of my workers found this in his deceased granpa’s barn, and I want to get it to the shop and make sure it’s real. May be a bit. His grandpa bought the car new, and they had it crushed several years ago. I know. Sad deal. It started with him telling me on the way home the other day that he never knew Chevy made a 302. We started talking, and he said I power washed it and took pictures. And sure enough, it looks legit. He’s bringing it down when we get caught up.
don,t have one
Old 04-29-2018, 08:06 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Depends on which year. The casting numbers on the block, heads and intake will tell a lot. The '67 is the rarest; 602 were built. and complete engines were not offered through the parts network.
Old 04-29-2018, 08:22 PM   #6
randy wilson
It came out of a 69. I’ll look up the numbers when I get it down here.
don,t have one
Old 04-29-2018, 09:20 PM   #7
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Randy,before you do anything, call Jerry and talk with him regarding the stamp pad on the block.
He'll tell you what the code is for the 69 Z28 engine,and most importantly,what not to do to when cleaning it up to see it clearly.
Dana Fitzpatrick is offline   Reply With Quote
Old 04-29-2018, 09:35 PM   #8
randy wilson
Will do. I promise. I’ve never actually been inside an original one.
don,t have one
Old 04-29-2018, 09:42 PM   #9
MAURICE BLENDHEIM
Liked 277 Times in 86 Posts
Randy… Does it have oil filler tube or not? Does it have bolt hole heads or not? Finned valve covers or stamped steel? MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 04-29-2018, 09:54 PM   #10
randy wilson
I know it has finned valve covers, I’ll look closer at the pictures tomorrow when he comes in. I do know it has straight plug heads. I spotted that.
don,t have one
