Old 04-28-2018, 03:10 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default GM three speed automatic with brake for SS
Racers,
the engine combination I am considering [350/360/325] SBC requires a three speed trans.
Tell me about your experience with trans brake with three speed. It will be in a 3100 pound door car, expected ET 9.70 range
What is a common trans folks are racing for this situation?
Larry Woodfin 471W
Old 04-28-2018, 03:31 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: GM three speed automatic with brake for SS
Larry, I have used a Rossler T350, and a ProTrans, T350. Both work great. ProTrans is a couple hundredths quicker for me.
Ed Wright 4156 SS/JA
Old 04-28-2018, 05:26 PM   #3
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
I am using a T350 with a brake in my 3100 lb SS/CA Corvette. It's been pretty reliable. Only thing I would change from what I have now is to upgrade to a clean neutral valve body/shifter. It seems all the good transbrake valve bodies for T350s are reverse pattern.
Old 04-29-2018, 11:18 AM   #4
Ed Wright
Ed Wright's Avatar
Clean Neutral is nice.
Old 04-29-2018, 01:50 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Kilgore Superlite works well , he will build it with a Reid Case if you want it .
Old 04-30-2018, 01:52 PM   #6
nhramnl
Liked 358 Times in 83 Posts
Two things...
First, I heard a long time ago that the low-reverse drum has to change directions on the 1-2 shift in a TH350, and that makes the 350 trans less quick. I'm not stating that as a fact, so don't mob me, please.
Second, doesn't anybody like McClay's THM 200s?
Old 04-30-2018, 02:39 PM   #7
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Originally Posted by Dragsinger View Post
Racers,
What makes you think you have to run a TH350? They opened the rules up so a powerglide car can run a th350 so I think you could run a glide if wanted.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-30-2018, 03:56 PM   #8
Dragsinger
Terry,
if I can run a Powerglide with the 350/360/325 that will sell the deal. I would much rather run the glide than a 3 speed.
Larry Woodfin 471W
Old 04-30-2018, 06:19 PM   #9
ss3011
ss3011's Avatar
Doesn't reverse direction on the 1-2 shift , but does come to a stop . Then spins up the same direction as the engine when making a 2-3 shift . The Superlight reduces that inertia dramatically for both those shifts , that is why it's so fast !
Old 05-01-2018, 09:44 AM   #10
Eman
Liked 133 Times in 76 Posts
Which part are you talking about? There is no drum for low/reverse only drums are forward and direct.
Eman is online now   Reply With Quote
