Old 04-20-2018, 06:23 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Mounting Turbo Action Shifter
I just purchased on of these to go into my cuda and am looking for some mounting options. There is no center console in the car and would like to see what other people have done
Thanks
Dave
Old 04-20-2018, 11:55 PM   #2
Demon340
Liked 108 Times in 29 Posts
Default Re: Mounting Turbo Action Shifter
I bolted it directly to the tunnel with 1/4 inch bolts on our A body cars. My sons was little better fitting because of old floor shifter and the tunnel was flatter.
Larry
Demon340 is offline   Reply With Quote
Old 04-21-2018, 12:17 AM   #3
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
^^^^^^^ Ditto ^^^^^^^^
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 04-21-2018, 01:03 AM   #4
David Lee
Larry
Thanks. do you directly bolt it the floor boards and mount a little higher higher?This is for a 67 notch
Old 04-21-2018, 08:03 AM   #5
Liked 10,652 Times in 2,210 Posts
Bolt it to the floor after you find out what is a comfortable location for you.
Old 04-21-2018, 10:14 AM   #6
jimmyparker
Liked 302 Times in 86 Posts
I usually space the front of the shifter up some as the neutral safety switch is tight against the floor in some applications.
jimmyparker is offline   Reply With Quote
Old 04-21-2018, 01:45 PM   #7
Demon340
On my son's 73 Dart we used washers under the back because of the angle of the cable going through the floor. Like others have said, what fits best for your comfort.
Old 04-23-2018, 06:13 PM   #8
Rick Kolber
Liked 32 Times in 13 Posts
Mine is mounted on a pedestal on the tunnel bringing the shifter up an closer to me.
Rick Kolber is offline   Reply With Quote
Old 04-23-2018, 06:29 PM   #9
David Lee
I made my own mount, using the 3/16 aluminum plate with specers to make it higher.
Thanks to all for the help
Old 04-24-2018, 03:52 PM   #10
65signet
Liked 44 Times in 21 Posts
I use a piece of angle iron, so its sits up higher, and i weld the angle to the floor, with some flat bar on the other side for support, then bolt the shifter to angle.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
