Old 04-17-2018, 06:52 PM   #1
Chris1529
Liked 70 Times in 29 Posts
Default MT Pro Drag and Pro Bracket Radials
Anyone know what the main differences are between the MT Pro Drag Radial and the Pro Bracket Radial. I do see a compound difference and some size differences, but are there any other major differences?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-18-2018, 10:48 AM   #2
Mike Mans
Liked 299 Times in 48 Posts
Default Re: MT Pro Drag and Pro Bracket Radials
The Pro Bracket Radials are an awesome tire that will last a LOT longer than the Pro Drag radials. That being said - they are quite a bit heavier. A lot more rubber thickness on the wear face for the ability to last longer. And the Bracket version is a shorter rollout, which will result in a couple hundred higher finish line RPM.
Mike Mans is offline   Reply With Quote
