Old 02-15-2018, 01:20 PM   #1
J&S Racing
Liked 327 Times in 87 Posts
Default Looking for advise on fuel system
Getting ready to order the fuel system for my stocker project.
Trying to decide if I should run the Magnafuel pro star 500 or the A1000 stealth set up from Aeromotive.
Looking for opinions on what rout you would go and why.
Old 02-15-2018, 01:46 PM   #2
Jim Craig
Liked 5 Times in 3 Posts
Default Re: Looking for advise on fuel system
don't forget to look at Weldon
Jim Craig is offline   Reply With Quote
Old 02-16-2018, 05:48 AM   #3
GTX JOHN
On all our small block stocker/SS cars we run basic Holley Blue/Black or Mallory 140 as the high dollar stuff
and recirculation stuff never helped us at all and was expensive.
However, Our float bowls look like 55 gallon drums on thermoquads and are fed by two large needles and seats.
Your results may be not be the same with different carb. setups!
John Irving
741 Stock
741 Super Stock
Old 02-16-2018, 08:26 AM   #4
J&S Racing
For what it's worth this is a 396/375 with 780 quick fuel....I was told this combo needs a lot more pump than one would think.
Another question, are you guys running the braided line back to front or using solid tubing for the length of the car?
Old 02-16-2018, 12:12 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I ran a Magnafuel Quckstar 275 on 302 Ford with a 4150 at 600 cfm and it was nice and quiet until it sprung a leak at the bottom O ring. I replaced it with a Holley Black. It's loud as ## but gets the job done.
Dale Shearon
68 Mustang 6394
Old 02-16-2018, 12:18 PM   #6
FireSale
FireSale's Avatar
-10 to the second filter at the fenderwell and -8 to the carb. it's a 750 now. the motor likes it better than the 600. I thought about hard lines, too. Couldn't find over 5/16.
Dale Shearon
68 Mustang 6394
Old 02-16-2018, 12:38 PM   #7
Rory McNeil
I`m like Mr. Irving, nothing fancy. My Stocker Mustang used a Holley "blue" pump and regulator, using 3/8" steel tubing front to back. My low 10/high 9 second big block bracket car has used the same twin Holley "blue" pumps for over 30 years, still working fine. I have a 5 gallon fuel cell with 3/8" tubing from each outlet of the cell into each pump, then a Moroso Y block with 1/2" aluminum Moroso tubing up to the engine compartment, where it has another Y block with 3/8" lines, each line feeding a Holley blue regulator, and then each regulator feeds a float bowl of a Holley 780. Obviously, with 2 good sized float bowls, a Holley is easier to keep supplied with fuel, that say a Quadrajet. I have seen some Stocker Q Jet fuel systems that would likely be more than sufficent to supply a Pro Stock engine. A tiny single float bowl with 1 needle & seat must be a challange to keep full.
NHRA 6390 STK
M/S 85 Mustang
