Old 02-11-2018, 04:59 PM   #1
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default 16 volt systems
This is a question for my son's car and not for my stocker. Can anyone advise me on how guys are using the 16 volt battery systems? Does he need a special starter or ignition system? He runs two batteries so he could separate the gauges, etc. if necessary.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 02-11-2018, 07:08 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: 16 volt systems
I changed nothing. My starter spins faster, coil puts out a hotther spark, lights are brighter, but bulbs don't last real well.
Ed Wright 4156 SS/JA
Old 02-11-2018, 08:05 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Most newer race components have been designed to be run at 16 volts .
The one exception might be electric radiator fans . ......Most are designed primarily for street use .
I've seen a few cars that have had fan motor failures . ...a dropping resister or module takes care of the problem .
Old 02-11-2018, 08:58 PM   #4
Jeff Niceswanger
Liked 1,041 Times in 369 Posts
Be careful charging it. 16 volt chargers put out almost 20 volts ... That WILL burn things up if you leave your kill switch on. We burnt up a MSD box and when repaired I called and ask why ? Technician said "The 18 volt threshold had been reached"......
Jeff Niceswanger 3740 SS
Old 02-12-2018, 01:00 AM   #5
Richard Grant
Thanks guys. I was hoping that it would be an easy change. Can you recommend where to purchase the battery and charger also the best brands.
Old 02-12-2018, 10:25 AM   #6
Hacksaw
Liked 314 Times in 177 Posts
Unsure of latest builder of 16 v batts but I think the Moroso 12v / 16v charger is the best out there.
Old 02-12-2018, 11:10 AM   #7
Ed Wright
Ed Wright's Avatar
Forgot about fans. I have had to replace the motors in my factory fans. They sure do spin up on 16. LOL
Anybody else having to buy new 16 volt batteries every season?
Old 02-12-2018, 10:25 PM   #8
Hacksaw
Ed: I have only used the Turbo Start brand of 16 v batts. I went 6 years or better with the big batts., changed to the lite weights after cause I felt guilty. The Moroso charger, maybe, was the key, don't know. I will be buying new Turbo Starts for my next racecar soon.
Old 02-13-2018, 11:44 AM   #9
Ed Wright
Ed Wright's Avatar
I have 2 16 volt Xcess (spelling ?) in it now. Not light weights. The 2 Turbostarts that failed last season. A DSR charger.
Maybe these will go another year. This DSR charger supposedly goes into a "maintainer" mode. Hope it does.
Old 02-13-2018, 12:41 PM   #10
340Cuda
Liked 805 Times in 341 Posts
One thing to consider about a 16 volt setup is availability. You need a backup plan.
My son manages an Interstate Battery dealership and they can get, but do not stock 16 volt batteries.
It is not usual for him to get a desperate call from a racer whose 16 volt battery has failed, they need one to go to the races and cannot find one locally.
Bill.
