Old 02-05-2018, 07:29 PM   #1
qflash
Default NHRA fuel check
What are you Stock and Super Stock racers using for the required fuel check? New to Stock racing.
Thanks
qflash is offline   Reply With Quote
Old 02-05-2018, 08:58 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: NHRA fuel check
About as cheap as you will find and works... http://quartermax.com/fuel-sample-valve/
Rich Taylor
I/SA - 321
Old 02-05-2018, 09:11 PM   #3
qflash
Thanks so much. Just ordered one.
Ron
Old 02-05-2018, 09:41 PM   #4
NORMAN BARNARD
Liked 2 Times in 2 Posts
Just curious but what is the devise being used to check fuel for
chemical content or diaelectic spec.?
NORMAN BARNARD is offline   Reply With Quote
Old 02-06-2018, 10:10 AM   #5
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Here's one w/o the hose: https://www.appliedracing.com/an-fit...ple-valve.html
and a brass one: https://www.mcmaster.com/#7910k11/=1bg9eu0
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 02-06-2018, 12:45 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
Originally Posted by GallopinGhost View Post
Do not use the lever type of valve. I had one and bumped the lever working under the hood and had a bad fuel leak. Lucky it did not cause a fire. Now I use the push button type that cant stay in the open position. That was a lesson learned and a first round loss. I got mine from either Jegs or Summit.
Mike Pearson 2485 SS
Old 02-06-2018, 02:10 PM   #7
340Cuda
Liked 805 Times in 341 Posts
So you don't have to pull the fuel from a fuel line under the hood?
This looks like it just pulls a sample from the tank.
Thanks,
Bill
Old 02-06-2018, 03:09 PM   #8
Mike Pearson
Thanks,
Bill
That one mounts on the regulator. Push in and the fuel comes out of the tube. Release and it stops. Looks like a nice way to do the job. As far as I know you have to take the sample from under the hood.
Old 02-06-2018, 04:31 PM   #9
HandOverFist
"Pumps/Valves: Cars equipped with carburetor(s) or nonelectronic
fuel (EFI) systems but with mechanical non-OEM fuel
pumps must have a quick-action fuel-shutoff valve within easy
reach of driver and located in the main fuel line between the
fuel tank and the carburetor and/or injectors. Fuel recirculation
systems not part of normal fuel/pump system prohibited. All
cars in Stock, Super Stock, Competition, and Pro Stock must
be equipped with a positive-lock drain valve located between
the fuel tank and the carburetor(s) or fuel injector to facilitate
removal of fuel samples for fuel-check purposes."
Rich Taylor
I/SA - 321
Old 02-06-2018, 04:37 PM   #10
GallopinGhost
http://www.jegs.com/i/Aeromotive/027/15631/10002/-1
Brian Carpenter
Stock 1358
