Old 01-09-2018, 03:11 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Trans shield rule??
I am looking for some clarification on the new TRANS SHIELD rule.
What is required for a trans shield / blanket?
Will an ultra bell be good, or do you need more?
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 01-09-2018, 03:54 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Trans shield rule??
I was not aware they changed it this year. Glad I saw this while mine is out of the car.
Ed Wright 4156 SS/JA
Old 01-09-2018, 04:26 PM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
From what I understand when you're in Stock Eliminator and running quicker than 10.99, you must now either have a SFI-approved trans case (ATI, Reid or JW case), a SFI-approved shield or a SFI-approved blanket. An SFI-approved bell housing isn't required on any Stock Eliminator automatics unless you're quicker than 9.99 from what I recall.
Jim Kaekel 3836 STK
Old 01-09-2018, 04:34 PM   #4
Mark Callanan
Liked 64 Times in 14 Posts
Is that 10.99 based on the Index?
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 01-09-2018, 05:04 PM   #5
btrc
Liked 84 Times in 42 Posts
No, I understand the 10.99 is based on what you actually run. If one car ran 10:98 he would need it and if an identical car ran 11.01 he would not need it. I would hope I am wrong on this but it is what I have been told.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 01-09-2018, 05:06 PM   #6
Ed Wright
Ed Wright's Avatar
So, nothing for SS? I have a TCI shield on mine. Where did you guys see the new rule changes?
Old 01-09-2018, 06:27 PM   #7
Mark Callanan
I think this is still waiting to be finale
Don't feed into it all...
Old 01-09-2018, 06:45 PM   #8
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
Here's the wording for stock...
"any car running quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1. Any car running quicker than 9.99, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory. See General Regulations 2:12, 2:14."
General reg 2:14 doesn't provide any further clarity but if running a car that goes 10.99 or quicker then I sure wouldn't show up without a blanket or shield. May very well be one of the "easy tech" items they can check easily in the lanes, kinda like tethers; they just have to bend down further.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-09-2018, 06:50 PM   #9
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Stock rule is here:
Any car running quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1. Any car running quicker then 9.99, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory.
As already posted, the Ultra Bell alone is not a transmission shield, but will serve as the flexplate shield if you need one.
Super Stock rule appears to be the same as last year. It is basically the same as the Stock rule, but there are also class-based requirements in addition to ET-based:
Cars in SS/AH through SS/MA, FSS/A through FSS/M, and any car running quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1. Cars in SS/AH through SS/JA and FSS/A through FSS/M, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory. Aftermarket automatic transmission bellhousing permitted; must be labeled as meeting SFI Spec 30.1 for automatic transmission flexplate shields and must be NHRA-accepted. Aftermarket OEM-style replica case, NHRA-accepted, permitted. See General Regulations 2:14.
Cars in GT/AA through GT/LA, FGT/A through FGT/J, and any car running quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1. Cars in GT/AA through GT/GA and FGT/A through FGT/J, SFI 29.1 automatic transmission flexplate and SFI 30.1 flexplate shield mandatory.
S/ST 51
S/C 53
Old 01-09-2018, 07:06 PM   #10
duster1256
duster1256's Avatar
Liked 20 Times in 3 Posts
What difference does it make on your e.t. If a transmission blows up I think you would
want the protection.
duster1256 is offline   Reply With Quote
